Maximum stress does not agree with analytical solution
    • hwa0725
      Hi all,
      I am trying to analyse a simple cantilever shear wall (Height: 72m; Breadth: 6m; Thickness: 0.275m) with a pressure of 110897 N/m2 applied to the surface of thin side (its thickness) and the stress calculated from ansys does not match with the bending stress I have calculated with simple analytical equation like moment, M = (wl^2)/2 and bending stress = M*c/I.
      I had tried meshing the solid with quadratic solid186 with 3 elements across the gap (i.e. thickness) and also tried to sweep the solid with solid shell 190 with 5 element across the gap. Both of these gave very different answers and does not seem to agree with my analytical calculations. I am sure the mesh is fine enough, finer mesh will take too long to solve. Not sure why is this happening and it would be great if someone can point out a few things that I can tweak to get better answer.
      Thanks very much for any help! Much appreciated!
      Best regards,
      Heng
    • peteroznewman
      Heng,
      Where are your hand calculations? Where did you come up with a pressure load of 110897 Pa?  That sounds like air pressure. You don't apply that to a cantilever beam.  A more realistic pressure is 50 Pa.
      I created a surface with the length and width of the beam and assigned the thickness.
      Hand Calculation      = 0.485 m
      ANSYS Deformation = 0.482 m (-0.6% error)
      Hand Calculation = 10.3 MPa
      ANSYS Stress     = 10.4 MPa  (1.5% error)
      If this answers your question, please mark the post Is Solution to make the discussion Solved, or ask a followup question.
    • hwa0725
      Hi Peter,
      Thanks very much for your reply!
      My apologies for confusion! The pressure load of 110897 Pa is actually a wind pressure (windward pressure + leeward pressure (suction)) that is acting of the thin side (72m x 0.275m) of a concrete shear wall. Also I have attached picture for my hand calculation and the a test model in .wbpz format. Thanks and appreciate your help!
    • peteroznewman
      Hi Heng,
      (1) Is this beam standing in the wind or is it inside a building? Because the aspect ratio is so high, 6 to 0.275 is about 22 to 1, what you have is more like a wing than a building. A small change in the angle of the wind will create large sideways forces. Also the sideways flexibility combined with the vortex shedding that may develop can set up an oscillation that will create large dynamic forces.
      (2) How did you come up with the value of Pressure load due to wind.  Here is a Cornell University webpage.  Using such high aspect ratio might take this calculator out of its valid range, but anyway...150 mph is 241 km per hour.
      Convert the maximum pressure of 62 psf and you get about 3,000 Pa, not 111,000 Pa.  How did you derive the value of pressure?
    • hwa0725
      Hi Peter,
      Thanks for your concern, they were great! Perhaps, I should have descript a bit more regarding what I am doing.
      (1) The Shear Wall I mentioned is actually part of a Core Wall (on plan: 6m x 6m, 0.275m thick) which is located at the center of the building, which on plan measures 18m x 18m. The total height of the building is 72m that consists of 24-stories of 3m floor-to-floor height. This is a modular buildings and the number M #01 ... M #16 are individual modular units which is prefabricated and prefinished in the factory and will be dropped into place floor by floor.
      The reason the shear wall seems relatively thin is because I would like to only analyse the A-A section as shown in plan below. I have inserted a Frictionless Support that scoped to both the front and back of the Shear Wall and apply the windward and leeward (suction) pressure to the left and right side of the Shear Wall respectively.
      (2) The wind velocity is calculated based on the Eurocode together with Local Annex. The wind velocity I had was about 90 kmph, which is about 56 mph. After converting it into a pressure, I ended up with +1205 Pa (windward) and -1054 Pa (leeward) wind pressure which add up to the 2259 Pa. This pressure 2259 Pa is then splitted into 2 as it will be resisted by 2 shear wall. So half the width of the building (18m/2) multiply by this sum of pressure acting on the facade would be the pressure carried by 1 Shear Wall. The resulting pressure need to be multiply by 1.5 (partial safety factor) to get to the final value which is around 30496.5 N/m. If I were to convert this back into a pressure acting on the side of the Shear Wall, this would be, 30496.5/0.275 (the thickness of Shear Wall) = 110897 Pa.
      Hope this clarifies a little. Thanks very much for you help! Cheers!
      Heng
    • hwa0725
      Also, mesh convergence study has been performed and not much luck seeing the stress at support converge but rather, diverge! The finer I go, the further it gets, not sure what went wrong to be honest. Could it be the boundary condition? I used ansys mechanical "Fixed Support" by the way.
    • hwa0725
      Deflection and first natural frequency have converged but the stress keeps increasing.
    • peteroznewman
      Here is the hand calculation for the Euler Beam Theory equations for your problem:
      Here are the results from the ANSYS Beam model of that problem:
      So you can see that a beam model almost exactly reproduces the hand calculation.
      Here are the results from the ANSYS Solid model of that problem:
      So you can see that a solid model almost exactly reproduces the hand calculation. I expect as I use smaller elements, I can get closer to the beam result.
    • hwa0725
      Hi Peter,
      Thanks for the reply!
      What type of mesh setting did you used to get the results of solid model? I have the same support condition and loading but the model is in concrete instead and I am getting stress increase every time I reduce the mesh size. That's strange!
      First, I had a 3m mesh, I got 16.57 MPa, which is quite close to the value you are getting.
      Second, I reduce mesh size to 1m, I am getting 18.29 MPa.
      Then when I tried 0.5m mesh, I am getting 19.94 MPa.
      It keeps incresing as the mesh size decrease.
      Best regards,
      Heng
    • peteroznewman
      Heng,
      Attached is my ANSYS 2019 R3 archive with the two models. I also checked if the normal stress was affected by Poisson's Ratio, but it wasn't.
      You can look for where your model is different to mine.
    • hwa0725
      Hi Peter,
      When I further refine the mesh you used, the stress shoot up again.
      After a bit of research, now I know where this gets wrong! It was due to stress singularity at the fixed support! This issue only shows up when using ANSYS default Fixed Support.
      This is a close-up snapshot of stress singularity at the toe of fixed end when using Fixed Support,
      This is a better stress distribution using Remote Dispacement (with all dofs set to 0),
      Also, the latter boundary condition shows no sign of divergence when the mesh gets finer and agree well with my hand calculation!
      Anyway, thank you very much for your support and dedication! I wish you the best and stay safe and healthy!
      Heng
    • hwa0725
      Also, for anyone that has the same issues as I did, stress singularity disappear only if you have a Remote Support (with all dofs set to 0) with a Deformable Behaviour! If you set this to Rigid Behaviour, it makes no difference to a Fixed Support and stress singularity will appear!
    • peteroznewman
      Heng,
      You misunderstand the difference between stress increasing due to a singularity and stress increasing due to elements getting smaller.
      I used a material with a Poisson's Ratio = 0 specifically to avoid non bending stress being caused by the fixed support. The stress at a singularity increases to infinity as the element size is reduced to zero. That is not happening here. Let me explain the stress increasing due to elements getting smaller.
      Below is the Element Mean stress for the Initial Mesh. The Element Mean stress is the value of stress at the center of the element. This is the fundamental quantity computed in the solution.
      The maximum element mean stress is 14.9 MPa which is measured at the center of that corner element.
      Now cut the element size in half and the max stress increases to 16.0 MPa, because the element center is closer to the corner.
      Cut the element size in half again and the max stress increases to 16.7 MPa, because the element center is even closer to the corner.
      I can cut the element size in half again. The stress increases again. I can plot the maximum element mean stress vs these four element sizes and predict the max stress at zero element size. It is not infinite as it would be for a singularity. The plot below is what you do in a Mesh Refinement Study. This stress is at the center of the element in the corner, not the stress in the corner of the material. This plot has a steep slope because the measurement point is moving through the material from lower to higher stress levels.
      There is another stress that can be plotted called the Averaged Stress, other programs call it Nodal Stress. That takes the stress at all the element centers connected to a single node and averages them. Then post processing interpolates across the element. This makes for a smooth result and the maximum value is the stress in the corner of the material.
      Below is the Initial Mesh and the interpolation out the the corner is 17.246 MPa.
      As the element size is cut in half, the averaged value increases to 17.469 MPa
      As the element size is cut in half again, the averaged value increases to 17.656 MPa
      If you plot these three plus the half again value, the slope of the Averaged Stress is less than the Elemental Mean because the measurement point is always in the corner and is not moving through the material as the element size is reduced.
      Again, the Averaged Stress extrapolates the stress out to the corner. But this is not a singularity.
      I hope you find this helpful.
      -Peter
    • hwa0725
      Peter,
      This is indeed very helpful for a new ANSYS user like me! I will save this for future reference really!
      Thank you very much for such a detailed explanation!
      Heng
Viewing 13 reply threads
