February 9, 2018 at 11:12 am
smlbysl
SubscriberI am using Maxwell 2D to analyze a transformer for transient and magnetostatic solvers. When I click analyze all, the simulation is completed suddenly (about in 4 or 5 second) but there is no error, no solution and result. In older simulations, it was analyzed longer and correctly. But, later this problem occured I tried to reset up the solution setup but it didnt work. What should ? do to be able to fix this .
June 26, 2018 at 8:14 pm
mchristi
Ansys EmployeeA model which runs in a previous version should run in a newer version. This sounds like a software configuration issue. Can you run any Maxwell 2D models at all?
June 27, 2018 at 12:03 am
smlbysl
SubscriberActually, I figured out this problem by reseting library directories in the general options. I dont know the problem but I tried haphazard and it worked. The problem not apeared again.
- Maxwell, HFSS or Q3D?
- Error
2656
2116
1343
1118
461
