February 20, 2018 at 12:36 pm
June 26, 2018 at 8:16 pm
mchristi
Ansys EmployeeMake sure there is a ground in each loop of the circuit. If it is ungrounded or floated, then add a large resistor like 1e8 ohms connected to ground.
June 27, 2018 at 12:08 am
smlbysl
SubscriberYes, I also added a large resistance between ground and each node at that time and it worked. The problem is disappeared. Thank you.
- Maxwell, HFSS or Q3D?
- Error
5290
3311
2471
