maxwell-core loss imported value
    • ma826
      Hi All,
      I did a two way coupling between maxwell and steady state thermal analysis. Then I wanted to export the result from thermal and feed it back to maxwell but it was not able to export and I found because of Nan value for core loss in maxwell .
      I created table value for core loss at Maxwell and it is Nan (no number). is there any one who can help me why it is Nan and how I can have a number for that?
      Regards
    • Mark Solveson
      Ensure that the Core Loss is turned on in Mxwell.
      Right click on Excitations -> Set Core Loss, and check the objects for which you want the core loss calculated.
      Note that only objects that have the core loss coefficients defined in the material definition will be available in this list.
