Maxwell Eddy Current: Electric Field from Coil
    • JacobT
      I'm trying to get a map of the electric field generated by a current-carrying flat coil on a parallel plane a short distance from the coil. I'm using Ansys Maxwell Eddy Current solver with the free student version.
    • HDLI
      Could you reduce scale of E field and maybe plot E in all the surfaces or in the object ? It seems that you just plot the E in bottom surface of the object, that might have low values.
      HDLI
