Maxwell Generate Mesh error: Failed to recover wired body (2023 R1)
    • Roland
      I use a segmented 2D model with 6 wires that are duplicated and rotated from wire_0. Validation check passes successfully. Wire_0 is drawn with a polyline that is covered to a surface. If only 5 wires are generated meshing works. But if 6 wires are generated the error occurs. I tried to redraw in several ways but I can not get rid of this error, Can anyone help me?
Viewing 0 reply threads
