April 13, 2023 at 3:44 am
Elvis Fernandez Perez
SubscriberI am using the Magnetic Transient Solver and I am getting some issues that prevent the tool to run. I am trying to simualte the movement of a body(in this case a person under Tramsmition Power lines. There errors are moving objects touchs the stationary band at the initial position and motion seet up is not valid. Any tips? I am leaving a snip
April 14, 2023 at 6:15 pm
Deyu Li
Ansys EmployeeHi, all moving objects need fully be fully nested inside band object and there should be some gap to band boundary.
- Maxwell, HFSS or Q3D?
- Error
5250
3299
2469
