July 3, 2018 at 6:12 am
Thierry
SubscriberI´m doing a 2D Simulation (Magnetostatic). I can´t run the simulation. Maxwell give me this error "Maxwell2d solver, process solver2d error: Internal Solver Error: 'Same Vertex for the begin and end of face'"
could anyone tell me how to solve that?
Thanks
July 4, 2018 at 12:15 am
Minxiang Wu
Ansys EmployeeDear Thierry,
Could you please provide more information about how you set up the model?
Thank you.
Best Regards,
Minxiang
July 4, 2018 at 5:30 am
Thierry
Subscriberi´have already found the solution. The boundaries was not correctly setr for the model.
June 17, 2020 at 7:49 am
domagojb
SubscriberHello, I'm doing a 2D magnetostatic problem. I got the same message in the Message Manager during solving: Maxwell2d solver, process solver2d error: Internal Solver Error: 'Same Vertex for the begin and end of face.' Model in this case is axisymmetric so ballon boundary is set to three outer edges instead of four (in case of XY models). Does anyone know how to fix this?
July 5, 2023 at 3:18 pm
sayantan
SubscriberHi while doing the 2D magneto static simulation, I am getting something called server error, I am using Windows 11 and Ansys student desktop 2022R2.
Is there a way to solve this issue or need to call ansys support or this is the issue with student version?
I am attaching the image for reference,
Regards
Sayantan
- The topic ‘Maxwell Magnetostatic (Solver2d Error)’ is closed to new replies.
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Concept of Interpolation Sweep in HFSS
- Error
8808
4658
3151
1680
1470
