Maxwell power electronics transformer simulation
    • yinan
      Hi! I encountered some problems when using Ansys Maxwell to do the simulation of a power electronic transformer, which is a 30kHz power ferrite transformer. The simulated core loss is only about 1/4 of the experimentally measured value and the winding loss is only about 1/2 of the measurement value. Has anybody encountered the same problem before? Is there any specific examples of Maxwell power electronics transformer loss simulation that would be helpful? Thank you!
    • Navya C
      Hi Yinan,
      Are you performing 2D or 3D simulation?
      If you are performing a 2D simulation, have you set the correct model depth under the design settings?
      Navya
