September 22, 2022 at 5:11 pm
September 28, 2022 at 2:34 pm
Navya C
Ansys EmployeeHi Kishan,
What error are you getting?
I am unable to view the first picture you added. Please share the error message/screenshot again.Regards,
Navya
September 28, 2022 at 2:37 pm
September 28, 2022 at 2:57 pm
Navya C
Ansys EmployeeAre you able to run the stand-alone maxwell simulation? Run any inbuilt example in maxwell and check if it solves without any error.
Share screenshots of how you set up the link between simplorer and Maxwell.
Navya
September 28, 2022 at 3:04 pm
Kishan
SubscriberYes, I'm able to run inbuilt example maxwell simulation standalone. Also, the my maxwell simulation runs well and completes the simulation when run stand-alone.
What specifically do I have to check when you ask for screenshot for the link between simplorer and maxwell?
I have a circuit built in simplorer, pmsm machine model imported from maxwell and a controller built using .dll model compiled from matlab simulink 2018b. I'm using ansys 2021.
September 28, 2022 at 8:03 pm
Howard
Ansys EmployeeHello Kishan,
Could you check and run an example in C:\Program Files\AnsysEM\AnsysEM21.1\Win64\Examples\Twin Builder\Components\Interfaces\Maxwell\TR-TR\2D ?
Could you just replace the Maxwell model with the inductance and resistance in Simplorer to test if you can run the Simplorer model?
HDLI
September 28, 2022 at 8:05 pm
Howard
Could you add small indutance between 3 phase input of the Maxwell block in the Simplorer model? Thanks.
HDLI
- Maxwell, HFSS or Q3D?
- Error
2616
2098
1323
1108
461
