February 9, 2022 at 10:27 am
Bobby11
SubscriberWhy am I getting below error?
"Coreloss: Output stator and rottorr object name error"
February 9, 2022 at 3:38 pmDeyu Li
Ansys Employeeyes stator and rotor loss could be seperated.
In project manager window, Analysis->Setup1. In the new window, go to Solver tab->check "Output per object core loss".
After checking that box, the report would have rotor and stator loss separated.
Note, this would only work when you are using materials with core loss model setup.
February 11, 2022 at 1:26 pmBobby11
SubscriberThank you ..!!
- Maxwell, HFSS or Q3D?
- Error
3744
2573
1809
1236
594
