May i get any help on Closed loop single channel natural circulation system?
    • AMShakil_MIST_BD
      Water will flow inside the closed pipe. Heat source will be provided along with a heat sink. Water will flow in one direction.n
    • Karthik R
      Administrator
      Hello, nWhat are the issues you are facing? How did you set-up your simulation?nThanks.nn
