May 5, 2022 at 8:56 am
Vishal789489
SubscriberI am trying to run a multiphase bioreactor run with different bubble sizes. As per the manual, Mean Diameter (Sauter mean diameter should be available for post-processing but Mean Diameter (Sauter mean diameter) is not showing up in variables section after musig run. Even the interfacial area density variable is not coming up.
May 18, 2022 at 12:30 pmVishal789489
SubscriberThe issue was resolved by increasing the volume correction factor and enabling the dropdown menu for gas variables
May 19, 2022 at 3:13 pmRK
Ansys EmployeeThanks for letting us know.
May 19, 2022 at 7:28 pmDrAmine
Ansys Employee:)
Viewing 3 reply threads- The topic ‘Mean Diameter (Sauter mean diameter) is not showing up in variables section after musig run’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3155
1688
1478
