March 16, 2021 at 12:35 pm
Rajan_Mistry
SubscriberIn HFSS, is there a quicker way to export the mean electric field magnitude in a component? So far, I am integrating the field w.r.t the volume of the component and dividing by the volume in the field calculator, but this seems to take a while. Is there a quicker way to do this?n -
March 16, 2021 at 5:03 pm
Rajan_Mistry
SubscriberFailing this, I would just like to know how to export the field data in a given component at all frequencies. Then, I could do post processing using Python or something else. I've had a look at output variables and the field calculator, but it doesn't seem to let you assign vectors/ 3D field results to an output variable.n -
March 17, 2021 at 1:17 pm
Praneeth
Ansys EmployeenI could not understand your question. Field calculator is kind of post processing tool and it can generate results within no time. Please let us more about your issue.nBest Regards,nn -
March 17, 2021 at 3:21 pm
Rajan_Mistry
SubscriberThanks for your reply,nMy expression in the field calculator is:nScl : /(Integrate(Volume(Cu2OsampleJR), Mag(Real())), Integrate(Volume(Cu2OsampleJR), 1))nnWhere Cu2OsampleJR is the element in which I want to calculate the mean E field inside it. I assign this as an output variable, then create a new report and plot this against frequency, but generating this plot takes a long time. I used a fast frequency sweep, with about 50 frequency samples (I would also like to do this for about 190 frequency samples too). nI suspected perhaps the integration is the time consuming part. In that case, is there a way to just export the 3D field data inside this element? I would like to export it as a csv or notepad file (something I can access with Python), and export the field at all frequencies (i.e have a single csv file with 3D field data in for a single frequency sample, therefore have about 50 csv files exported). I'd like to know how to do this, because once the data is exported I can process it myself.n -
March 18, 2021 at 1:12 pm
Praneeth
Ansys EmployeeHiArray,I would like to suggest you to use either Interpolating sweep or Discrete sweep type for you model and see whether you are facing the same issue.nAlso please read through the sections regarding Fast sweep for more information regarding it.nAll the very best.nBest regards,n
Viewing 4 reply threads
Trending discussions
- Maxwell, HFSS or Q3D?
- Error
Top Contributors
2630
2104
1329
1110
461
Top Rated Tags
