measure the minimum surface size for defeaturing value
    • manelaero2020
      Hi friends
      I want to measure the minimum surface size on my geometry in the order to enter this value into Ansys Meshing c(exactly defeaturing)
      Do you have an idea how I can do this (using Ansys space claim, DM, or meshing )?
      Thank you a lot
      Kind regards
      You can click on faces and see the size (bottom of screen). Not sure if there's a minimum size check as I've never felt the need to look for it.
    • Keyur Kanade
      Ansys Meshing does defeaturing based on edge length. You can see min edge length in Ansys Meshing under details of Sizing.
      Please go through help manual for more details
      Regards Keyur
    • manelaero2020
      thank you very much
Viewing 3 reply threads
