April 2, 2018 at 12:09 pm
maurya
Subscriberhello sir
i required rotation of one body wrt to other body.
first example i solved by reading some commands from internet.
this is single body fixed at bottom and moment of 1000 Nm at top.
For finding rotation commands are used for remote points and second command in solution.
measure_pilot=_npilot
and in solution
my_rotx=ROTX(measure_Pilot)*57.29
my_roty=ROTY(measure_Pilot)*57.29
my_rotz=ROTZ(measure_Pilot)*57.29
but if you calculate it by formulae: rotz is 4.01 correct by 16*t/G*j
question when i am using two or more bodies:
it is same as above with one more body body above that is placed having frictional contact with mue=0.8
I want rotational angle of lower body top outer edge and top body outer edge.
provide the command twice for two remote points.
two command are there but in solution how i will come to know for which body rotation is mentioned.
in this case i am getting same 4.015.
April 2, 2018 at 6:28 pm
SubscriberHere is a very simple way to apply a rotation and measure the torque. Use a remote displacement. The input is the rotation of 1 degree, the result is the moment required to rotate that face by that angle.
If you want to apply a moment and measure the rotation, create a Remote Point on the face and insert a result called a Flexible Rotation Probe. Below I applied a Moment of 25937 Nmm and I measured a 1 degree rotation. No code required.
April 2, 2018 at 6:54 pm
maurya
Subscriberhello sir
please send me the archieve file of this simulation.
My main aim is to find rotation of each vertebrae wrt to fixed vertebrae in my lumbar bone model for which you created the spaceclaim tutorial.
first i always try with simplify model to verify results. This seem absurd to you but without verifying the results it always doubt.
L1(top most ) wrt to L5(bottom one)
L2 wrt to L5
image just to remind the vertebrae
thank you
April 2, 2018 at 7:10 pm
SubscriberAttached file is an ANSYS 18.2 archive of the Moment and Flexible Rotation Probe.
August 29, 2018 at 9:34 am
August 29, 2018 at 11:23 am
SubscriberHello Mohankumar,
That result was added after 17.0
You will have to output the x,y, z undeformed nodal coordinates and the x, y, z deformation of a few nodes, spread out across the surface, then compute the rotation of that set of nodes using equations. Since it may not be rigid body rotation of the nodes, your equations will have to include a best-fit algorithm.
Perhaps other members can suggest an APDL command that does this, even though the functionality was not exposed in the Mechanical menu system at version 17.0.
October 5, 2018 at 1:24 pm
Ashish Khemka
Ansys EmployeeOne may add a general joint and then probe a joint rotation as well.
Ashish Khemka
May 17, 2020 at 2:11 pm
Subscriberahmadraza, please copy the content of your post and paste it into a New Discussion, then delete the post above.
It is better for you to have your own discussion since you will get notified when someone posts a reply.
2120
1347
1118
461
