November 8, 2021 at 7:34 am
Sherin
SubscriberI modeled a system in simplorer and I would like to measure THD of the output waveform.
Can any one please help me to tell the method adopted for THD measurement in simplorer
November 15, 2021 at 5:51 amNavya C
To calculate THD Right Mouse click on the plot ÔÇô Go to Trace Characteristics ÔÇô All.. ÔÇô Uncheck all except distortion
Set frequency equal to the frequency of your source/output and select the time range to calculate the function.
Results of distortion are already shown in percent, no need to multiply by 100.
Regards Navya
November 15, 2021 at 7:21 amSherin
SubscriberThankyou for your reply
May 29, 2022 at 1:40 pmphuonganhlovely.me
how to do it on maxwell (EDT ver 2022) I would like to measure THD of the output waveform.
please help me to tell the method adopted for THD measurement in maxwell
thanks you
- Maxwell, HFSS or Q3D?
- Error
3812
2593
1849
1244
600
