Discovery Import
Discovery Import
Measuring Velocity from an internal channel
    • tim.dukes
      Hi Support
      In the example below I want to know the average velocity at two areas highlighted.
      This is a very simplified version of an issue I am currently having.
      I can measure the velocity of an outlet face easily.
      I can take an average velocity measurement at a point as you will see in the file.
      Is there any way of finding out the average velocity from the two internal channels see highlighted edges in image below.
      The video may help explain -
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
  • Naresh Patre
    Hello Tim Dukes
    This capability is currently not exposed in Discovery and in the current release monitors can be created on a datum point in Explore. We hope to see this implemented in future versions, although I am not sure about its timeline.
  • Viewing 1 reply thread
