January 4, 2023 at 2:12 pm
Baragau Mihai
SubscriberHello!
I am a student, a beginner in this software, and I encounter a problem that I cannot solve. I have to build this annular section frame, everything is fine, until the moment when I have to connect the two bars so that they are joined correctly, without excess material on the outside, and with the inside empty. I hope I made myself understood enough. Thank you!
January 4, 2023 at 2:33 pm
Baragau Mihai
SubscriberTo be exactly, I need a 90 degree round bend of the same thickness as the pipes
January 4, 2023 at 5:36 pm
SubscriberInstead of two lines that intersect at a point, shorten each line by R then draw a quarter circle of radius R to connect the end points.
January 4, 2023 at 6:47 pm
January 4, 2023 at 6:54 pm
Baragau Mihai
SubscriberThe flat frame in Fig. 8.33 ring section is loaded with force F perpendicular to the plane of the frame. Knowing that D = 212 mm; d = 193 mm; a = 0.4 m;
E = 21.10^4 MPa; G = 8.1.10^4 MPa; F = 21 kN is required:
a) To determine the displacement of the point of application of the force;
b) To determine the maximum equivalent tension.These are the problem data.
January 4, 2023 at 11:36 pm
SubscriberTo have an elbow bend in a pipe of diameter D, the bend radius R should be > D. However, you don’t need an elbow bend to solve the problem as shown.
It doesn’t look nice, but it is perfectly acceptable to have a Finite Element model using Beam elements with a Tube cross-section meet at a point with a 90 degree angle between them. Just work with the lines and ignore the rendering of the cross-sections. However, your image of the tube cross-sections seems to show two lines that cross each other and did not stop at the point of intersection, is that true? If so, you must have lines that end at the intersection.
January 5, 2023 at 11:00 am
January 5, 2023 at 11:11 am
January 5, 2023 at 3:35 pm
SubscriberMesh lines with Beam elements. This is what you should choose.
Mesh surfaces with Shell elements.
Mesh solids with Solid elements.
The material should be Isotropic, don't use an Orthotropic material.
January 5, 2023 at 10:02 pm
Baragau Mihai
SubscriberI solved it. Thank you so much!
2088
1321
1108
459
