Mechanical ADPL issue!! “the solver failed with a non-zero exit code of : 15”
    • thinnestchips
      I have generated my mesh in Static Structural. Now when I try and port my model into Mechanical ADPL, I get this error message, please advise!!
    • Keyur Kanade
      Moving to structural mechanics category to get better response.
      Keyur
    • Aniket
      Need more information. Can you please insert images of error where do you get it?
      -Aniket
    • thinnestchips
      this is a screenshot of the error
    • thinnestchips
      I cannot see a structural mechanics category!
    • Aniket
      You are already moved to the structural mechanics by the mods. you can ctrl+F and search for "Structural Mechanics" to find the forum location.
      Also, regarding the error, it seems very strange. Are you able to do the following:
      Insert a command snippet in your static structural and then go to write input file as explained in https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/wb_sim/ds_writing_reading_ansys_files.html
      -Aniket
Viewing 5 reply threads
