August 14, 2021 at 2:23 am
panque
SubscriberHello everyone, I am having problems when applying loads on a node using Mechanical APDL 2021 R2, what I am doing is as follows:
First I create a spring element type then I assign a real constant, after this I model two nodes and create an element, when applying a displacement there is no problem but when applying a load there is warning (see attached image).
August 20, 2021 at 3:49 pmDave Looman
Ansys EmployeePerhaps the model is not constrained and that's why an applied displacement works. If a node has no stiffness, as would be the case in an unconstrained model, the node is removed. Is the node at the other end of the spring constrained? I'm assuming you aren't using any select commands that would have unselected the node.
August 22, 2021 at 3:55 pmpanque
SubscriberHi, thanks for replying, actually the model is well constrained. Im working on version 2021 R1 right now and it's working fine, but I have been unable to make it work on version 2021 R2. I have seen around the web the same problem but so far no solution. Thank you.
November 24, 2021 at 5:28 amsugandha
SubscriberHello
I am facing the same problem in R2 version. The point load on a particular keypoint/node is not working. Is it an error in the version or some procedure that we need to follow.
Thanks Sugandha
January 12, 2022 at 4:22 pmmjmmjm
SubscriberI am finding that the line or node selection does not work
I am hoping there is a correction to this available because without being able to apply loads or constraints Ansys is unusable
Viewing 4 reply threads- You must be logged in to reply to this topic.
Ansys Innovation SpaceSimulation World 2022
Check out more than 70 different sessions now available on demand. Get inspired as you hear from visionary companies, leading researchers and educators from around the globe on a variety of topics from life-saving improvements in healthcare, to bold new realities of space travel. Take a leap of certainty and check out a session today here.
Trending discussions- Fused deposition modelling , part simulation for residual stress
- Symmetry model
- Membrane element problem in soft pnuematic actuator (artificial muscle)
- What is incompressible material and what the examples of incompressible materials?
- Why the stresses from shell elements are higher or lower than the stresses from solid elements
- Convergence issue in non linear problem
- /Contour Function on Mechanical APDL
- Why am I getting the “the requested S data is not available the PLNSOL command is ignored” warning
- How to 3D print impact tested materials
- Why is the deflection for my analytical solution not matching ANSYS results
613
562
220
188
128
Top Rated Tags© 2022 Copyright ANSYS, Inc. All rights reserved.
