Mechanical APDL commands for stopping simulation when criteria has reached
    • joej
      I'm trying to run a static structural simulation with hyperelastic materials. Since displacement loads are more robust, I want to simulate that, even though ideally a force should be applied. How do I run the simulation to stop at the set force reaction? The image below is of a very simplified problem of the actual problem I'm trying to solve. I know about the NCNV command. NCNV, KSTOP, DLIM, ITLIM, ETLIM, CPLIM, set the key to terminate an analysis. I want to know how to use it. Any help would be appreciated
    • Ashish Khemka
