Ansys Free Student Software
Mechanical APDL doesn’t open
    • st619
      I have downloaded ANSYS Student 2019 R3 but when I try to open Mechanical APDL it doesn't open. I only see that.
    • st619
      after a while I see that.
      Should I do something with the antivirus or the firewalls?
    • tsiriaks
      Yes, try turning them off and see if it makes a difference. If so, turn them back on and add exclusions.
      In the meantime, you can try going to  Mechanical APDL Launcher -> HPC Setup tab -> Use SMP and specify 1 core.
      Thanks,
      Win
    • Yacir
      I have the same problem. I tried the above solution and unfortunately did not work.
      I think, the problem is this err.
      ErrorLogger.errorFilePath is C:Program FilesANSYS IncANSYS Studentv201CADConfigLogsCADConfigurationMgr.err
Viewing 3 reply threads
