Mechanical APDL freezes when i try to add an element type
    • williamhouston
      My Mechanical APDL opens fine, but when I try to add an element type it freezes. I have to start the task manager to close the program.
      I even tried setting other constraints, and they all seemed to work until I got to a constraint that needed an element type assigned.
      I have an ASUS laptop with the proper graphics card and processor.
      I have even uninstalled and reinstalled the software numerous times.
      Any suggestions?
    • Emmanuel Wonah
      Hi William,
      Did you find a solution to the above issue? I have just come across this issue and I have a workstation that should work just fine with the software. Any help or suggestion would be much appreciated. Emmanuel
    • Pavlina Kruzikova
      Hi both,
      I've encountered the same issue. Have you found a solution to this?
      Thank you,
      Pavlina
