January 26, 2021 at 7:15 am
kirstenbraun
SubscriberHello all,
I was busy changing some values in my model when all of a sudden some tab limitations occurred as if it were opened and the license was not recognised (e.g. the solve button amongst many other tabs and buttons is not pressable), however, the license error does not pop up and there is also no indication that Mechanical was opened under a "Read-only" mode (as you can see below).
January 26, 2021 at 8:07 pmRameez_ul_Haq
Subscriber,maybe a technical glitch. Its very rare to see this. There is a possibility for any software to get stuck. Thats why saving the work regularly is an important aspect, since even if you have to close the WB directly, the data won't be lost.nViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- Solver Pivot Warning in Beam Element Model
5346
3345
2471
1310
1016
