June 10, 2022 at 1:56 am
nkharel
SubscriberMy ANSYS Mechanical is crashing after about 30 seconds. Can you please help? -
June 10, 2022 at 1:23 pm
Ansys EmployeeMore details would help. What's it crashing into? -
June 10, 2022 at 2:33 pm
nkharel
SubscriberWhen I open the mechanical it opens, but after I press any key it closes automatically. I have been working in ANSYS for the past 5-6 months and it was working fine. But this problem suddenly arose 2 days back. I tried re-installing ANSYS but it didn't help. -
June 10, 2022 at 4:21 pm
George Karnos
Ansys EmployeeTry the following:
Close All ANSYS Aqpplications.Open Windows file explorer and type in the following in the addres line:
%APPDATA%\Ansys
This should take you toC:\Users\
\AppData\Roaming\Ansys There will be a directory named:v221 (for 2022 R1)
rename this to v221.old
now try to restartIf this doesn't work, there will be a directory named WorkbenchLogs
under %TEMP%Check the log files in there for errors.
June 11, 2022 at 5:31 pm
nkharel
SubscriberI changed the directory name and now it works fine.
Thank you @Geo Karnos.
June 18, 2022 at 2:55 pm
nkharel
SubscriberMy ANSYS Mechanical is still crashing. It crashes after the first click during startup. When I change my directory name to v221.old it works for 15-20 minutes and crashes. I have to change the directory name daily. The following message appears during first startup. -
June 18, 2022 at 2:56 pm
July 7, 2022 at 8:59 am
paul.pommier.pp
SubscriberI encounter the same problem. Any update ?
- License Error
- Workbench error
- Workbench not opening
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
3930
2649
1865
1272
610
