Ansys Products
Ansys Products
Mechanical missing in Workbench
    • jesuscal
      I installed all the modules available in the installer in FLUIDSTRUCTURES_2021R1_LINX64.tgz
      We have licenses for them, for example Mechanical and System Coupling... but they do not appear in Workbench.
      The license server is active and the licenses we have seem correct. Reading from the forum it seems this might be the first thing to check. Is there a command to check that the licenses for Mechanical and System Coupling are actually working?
      If the licenses are OK, what else might be causing that those modules do not appear in workbench?
      Thanks and best regards,
    • George Karnos
      Under the /ansys_inc/shared_files/licensing/ directory you should see a file named ansyslmd.ini
      This file will hold the license server name.
      You can run:
      /ansys_inc/shared_files/licensing/linx64/lmutil lmstat -a -c 1055@servername
      (change servername to the hostname of your license server)
      It is most likely a licensing issue. Paste the output from running that command... We can not open files.
    • jesuscal
      Thansk a lot for the answer. In ansyslmd.ini, the port of ansysli server appears (2325)
      I ran the lmstat command - these are the licenses listed (I split the list in 2 posts, since there seems to be a limit in body size)
      ansyslmd: UP v11.16.5
      Feature usage info:
      Users of 1spacdes:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of a_catv6_reader:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of a_jt_reader:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of a_spaceclaim_dirmod:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of a_spaceclaim_faceteddata:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of acdi_adprepost:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of acfd_vki:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of acfx_bldmdlr:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of acfx_pre:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of acpreppost:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of advanced_meshing:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of afsp_gui:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of afsp_optigrid:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of afsp_viewmerical:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of agppi:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of alinks_gui:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of am_module:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of am_prep:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of am_print:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of ans_act:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of ansrom:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of ansys:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of aqwa_pre:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of aqwa_solve:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of cfd_base:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of cfd_polyflow_ui:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of cfd_preppost:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of cfd_solve_level1:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of cfd_solve_level2:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of cfd_solve_level3:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of disco_level1:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of disco_level2:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of dsdxm:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of elec_solve_2d:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of elec_solve_hfss:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of elec_solve_icepak:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of elec_solve_level1:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of elec_solve_level2:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of elec_solve_level3:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of elec_solve_maxwell:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of elec_solve_q3d:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of elec_solve_siwave:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of electronics_desktop:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of electronics2d_gui:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of electronics3d_gui:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of electronicsckt_gui:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of ema_gui:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of ema_solve:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of emag:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of ensight_enterprise:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of envision_pro:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of explicit_advanced:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of explicit_basic:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of fluent_meshing:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of fluent_meshing_pro:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of fluent_setup_post:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of fluent_setup_post_pro:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of forte_3:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of granta_sim_mat_data:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of ice_translator:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of mat_designer:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of motorcad:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of motorcad_im:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of motorcad_pm:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of motorcad_sync:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of nspice_apl:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of nspice_hicap:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of nspice_sv:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of pemag:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of pexprt:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of piautoin:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of picatv5:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of piproe:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of pisoledg:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of pisolwor:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of piug:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of rd_ckcompute:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of rd_ckgraph:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of rd_ckpost:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of rd_ckpreproc:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of rd_ckui:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of rd_fortemesh:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of rd_forteui:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of rd_forteviz:(Total of 110 licenses issued;Total of 0 licenses in use)
    • jesuscal
      Users of rd_kineticsapi:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of rd_mechforte:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of rd_mechmfc:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of rd_mechsoot:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of rd_mechwb:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of rd_reactionwbui:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of rdacis:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of rdpara:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of redhawk:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of redhawk_apl:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of redhawk_caching:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of redhawk_gds2def:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of redhawk_inductance:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of redhawk_lef2def:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of redhawk_mpr:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of redhawk_netlisting:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of redhawk_passchk:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of redhawk_pwrcalc:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of redhawk_sim0:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of redhawk_sim1:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of redhawk_sim3:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of redhawk_spice_pkg:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of redhawk_vcd:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of simplorer_advanced:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of simplorer_control:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of simplorer_CProgrInterface:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of simplorer_gui:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of simplorer_LibSMPS:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of simplorer_sim:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of simplorer_sim_entry:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of simplorer_vhdlams:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of siwave_level1:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptArtist:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptDirectDotLib:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptGAFSplit:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptHDL:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptIPWizard:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptMixedLanguage:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptMixedVT:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptMultipleTestBenches:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptMultipleVoltages:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptPowerGating:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptSOC:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptSPEFCapacitance:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptSynLib2Alf:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptSystemVerilog:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptTBEngine:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptVectorless:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptVectorSelector:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptVWEngine:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptWSEngine:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptWWALFLint:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptWWEngine:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptWWGAF:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptWWSim:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptWWUI:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of sptWWVCDPlus:(Total of 110 licenses issued;Total of 0 licenses in use)
      Users of anshpc:(Total of 180 licenses issued;Total of 0 licenses in use)
    • jesuscal
      Hi Any suggestions on the next steps?
      Thanks and kind regards
    • George Karnos
      What is the exact contents of the ansyslmd.ini?
      If running 2021 R1 only, It should be :
      SERVER=1055@servername
      If running earlier versions also, it should be:
      ANSYSLI_SERVERS=2325@servername
      Under the user's home directory, there should be a .ansys directory that holds licdebug files
      Do those contain any errors?
    • jesuscal
      The version installed is only 2021, but the ansyslmd.ini file contains 2325, instead of 1055:
      ANSYSLI_SERVERS=2325@192.168.2.10
      I see the log file ansyscl.servername.42727.20679.log, though there are no errors - just checkpoint info...
      Server has been running for 7 days, 0 hours, 0 minutes, and 0 seconds.
      and ulimit status...
      core file size(blocks, -c) 0
      data seg size(kbytes, -d) unlimited
      scheduling priority(-e) 0
      file size(blocks, -f) unlimited
      pending signals(-i) 1029468
      max locked memory(kbytes, -l) unlimited
      max memory size(kbytes, -m) unlimited
      open files(-n) 1024
      pipe size(512 bytes, -p) 8
      POSIX message queues(bytes, -q) 819200
      real-time priority(-r) 0
      stack size(kbytes, -s) 8192
      cpu time(seconds, -t) unlimited
      max user processes(-u) 4096
      virtual memory(kbytes, -v) unlimited
      file locks(-x) unlimited
      Thanks again
    • George Karnos
      Change the ansyslmd.ini file to look as follows:
      SERVER=1055@192.168.2.10
      Now open workbench, Do the Systems show?
    • jesuscal
      Hi It seems to work now. Thanks a lot!
Viewing 8 reply threads
