Mechanical Results Tracker coordinate system
    • John Doyle
      Mechanical Results Tracker is using the 'NLHIST' command under the hood. All results are tracked in the Solution Coordinate System (that is, nodal results are in the nodal coordinate system and element results are in the element coordinate system). Refer to the MAPDL Command Documentation 'NLHIST' command for more details about capabilities, assumptions and limitations.n
    • Ashish Khemka
      Thanks for sharing this.Regards,nAshish Khemkan
    • Ashish Khemka
