July 30, 2019 at 2:44 pm
rdk9000
SubscriberWhen using static Static Structural I cannot get mechanical to run from workbench.
July 30, 2019 at 2:50 pm
George Karnos
Ansys EmployeeHi,
Can you please attach a screen shot of the error you are receiving?
Thank You,
Geo
July 30, 2019 at 5:38 pm
rdk9000
SubscriberHello there! I'm not receiving an error the mechanical screen opens but is just dark gray. It never times out, I let it go for 30 min and waited on an error but nothing. I can open APDL and run it, I can also run space claim. The error in the picture in Workbench is due to me closing out mechanical.
July 30, 2019 at 5:41 pm
tsiriaks
See the suggestions here
https://forum.ansys.com/forums/topic/installation-issues-and-starting-problems-geometry-editor/?order=all#comment-d679f502-c0dd-4edc-87b5-a98801843d73
Thanks,
Win
July 30, 2019 at 6:03 pm
rdk9000
SubscriberTried all the suggestions and still the same issue.
July 30, 2019 at 6:51 pm
tsiriaks
Ansys EmployeeWhat graphics card you have on the machine ?
What is the output of
ping %computername% -4
from CMD Prompt ?
July 30, 2019 at 10:43 pm
rdk9000
SubscriberGraphics card is NVIDIA GEForce GTX 950
what computer name am I pinging
July 31, 2019 at 12:04 am
tsiriaks
Ansys Employeeyou can copy the entire line and paste it there
Also, try issuing the command
dxdiag
then post the screenshots of default page and the Display tab(s)
July 31, 2019 at 1:06 am
rdk9000
SubscriberPinging LAPTOP-FRS81GFL [192.168.1.153] with 32 bytes of data:
Reply from 192.168.1.153: bytes=32 time<1ms TTL=128
Ping statistics for 192.168.1.153:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
July 31, 2019 at 1:53 pm
SubscriberI had the same problem. Open as Administrator a Command prompt and run the following commands:
regsvr32.exe ole32.dll
regsvr32.exe atl.dll
regsvr32.exe oleaut32.dll
regsvr32.exe scrrun.dll
regsvr32.exe jscript.dll
regsvr32.exe vbscript.dll
Then delete the files in the %APPDATA% Local and Roaming for both the ANSYS and SpaceClaim folders.
These actions might make Mechanical work properly.
July 31, 2019 at 2:13 pm
rdk9000
SubscriberIT WORKED!!!!!!!!!!!!!!!!!!!!!!!! After a week of headaches I can finally access it!!!!! Thank you so much!
So what exactly was happening?
July 31, 2019 at 4:32 pm
SubscriberIn my case, the computer has both anti-virus and cyber-security programs running that I cannot turn off. One of those blocks the part of the ANSYS installer that registers these dll's in the registry.
July 31, 2019 at 9:12 pm
tsiriaks
Ansys EmployeeNow I'm confused since you said you tried all suggestions in
July 31, 2019 at 9:16 pm
rdk9000
SubscriberHi there! I did try everything, I don't believe there was a section that said to delete the files. Nevertheless the solution worked. Thank you for your help.
July 28, 2022 at 5:35 pm
ankitagarg2994
SubscriberI have gone through all the suggestions and found the solution. In my system cyber-security programs running which I was unable to off. But somehow. I have followed cyber security training and was able to manage to perform the task.
- Workbench error
- Workbench not opening
- License Error
2564
2078
1293
1106
459
