April 30, 2023 at 5:48 am
Paco Sheeran
SubscriberHi,
I'm a newbie to fluent. I am trying to model the melting of a warm object through a block of ice and see how fast it will melt said ice and get to the bottom based on the temperature at the surface of the object. When I simulate this in fluent using solidification/ melting, the liquid fraction shows that ice is melting below the object, but it is not moving, it's basically floating. I checked that gravity is on but it still doesn't move. Is this simulation possible with fluent and if so what is the procedure for it? Thank you
Paco
May 2, 2023 at 3:42 pm
Ansys EmployeeRead how the solidification model works: it won't melt to give you floating ice.
May 3, 2023 at 5:51 am
Paco Sheeran
SubscriberI’m sorry I might not have explained it very well, or I am not quite understanding your explanation sadly. I’m not exactly looking to simulate ice floating. More so trying to simulate a warm object melting through the stationary ice. The warm object I simulated in the ice stays in position even when the ice around it has melted. It should be falling down with gravity if there is no ice holding it up. At least that was my assumption.
I believe it is possible for Ansys fluent to do this because I have seen the concept published in journal articles such as the one linked below
https://link.springer.com/article/10.1007/s12206-022-1249-5
Does this make sense, thank you
May 3, 2023 at 8:47 am
Ansys EmployeeAh, so a falling solid? OK. Still not easy, but have a look at the 6DOF (possibly 1DOF) solver and moving mesh.
May 26, 2023 at 6:42 am
Paco Sheeran
SubscriberHi again,
I tried that 6 dof solver and moving mesh and I think I made some progress, thank you. I just keep running into what appears to be a common error which is negative cell volume detected. I have tried what appears to be the typical problem which is too big of a mesh and timesteps too fast but neither of those really seem to work. I attached a picture of the setup. Do you have any thoughts on why this may be happening when trying to do melting/solidification simulations? The other solutions I have found on other forums don't really seem to work and most of those solutions are not for melting/solidification. Thank you
May 26, 2023 at 8:57 am
Ansys EmployeeI can't remember if full remeshing is availble for hex/quad elements. Check the documentation, you may want to retry with tet/tri.
June 4, 2023 at 3:49 pm
June 5, 2023 at 8:29 am
Ansys EmployeeThe above are hex cells, so I assume you also tried with tri as asked. If you work out the motion speed how many time steps does it take to cross a cell?
June 7, 2023 at 2:24 pm
Paco Sheeran
SubscriberYeah so I have tried it with all the possible mesh types I see in mesh, I showed the tri on this one I think.
So the motion speed is sort of what I am trying to find with the simulation in the first place so I am not entirely sure how to calculate it. If I do the same simulation without 6dof on though I find that after 5000 time steps of 0.001s the liquid/solid boundary layers appears to have moved about 1.5 cells. So knowing that I am assuming it would take about 3333 times steps to get across the cells currently. Is that a reasonable way to assume that?
June 7, 2023 at 2:25 pm
Ansys EmployeeMore-or-less. However, if you move more than one cell length the risk is you turn the cells inside out: the nodes can't reconnect (remesh) before they're corrupted.
5454
3417
2473
1310
1022
