November 11, 2019 at 9:32 am
krishnarajvvv
SubscriberPlease help me to do a numerical simulation of melting and solidification of PCM with convection in 3D geometry.
November 12, 2019 at 4:38 pm
Ansys EmployeeWhich part are you stuck on?
November 19, 2019 at 8:06 am
krishnarajvvv
Subscriberis melting/solidification model is sufficient for the analysis? how to give property values for wax at solid and fluid form? can you send a base model analysis output ,
November 19, 2019 at 11:33 am
Ansys EmployeeMaybe? How about you start by explaining what you're trying to model? Then check the tutorials in the Fluent documentation (click on Help and go from there).
November 21, 2019 at 5:08 am
krishnarajvvv
Subscribera cylindrical metal container with a small tube at the centre. through the centre tube, hot water is flowing and the space between the pipe is filled with wax in solid-state. this is my base model
November 21, 2019 at 5:11 am
krishnarajvvv
SubscriberSir, can you help me to analyze the model with CFD, if you can send me the output file, I know, it's not right to act those help. sorry really its a mini project with time constraints of 1 month
November 21, 2019 at 3:57 pm
Ansys EmployeeSo, you'll need to look at VOF multiphase (water & wax) as the two phases. Then look at the solidification/melting model for the wax.
We don't provide models, and certainly won't be doing your project for you: the software & our input are to help you learn.
5364
3351
2471
1310
1018
