June 30, 2020 at 9:14 am
sunil.voleti
SubscriberHello everyone,
I am simulating melting behaviour of glass substrate with laser as heatsource.can anyone please explain How can I simulate melting and solidification of glass in Ansys fluent.
June 30, 2020 at 10:30 am
Ansys EmployeeAssuming it's a normal viscosity model without any plastic or viscoelastic properties then the melting/solidification model ought to do it. Do you need the laser, or can you just add heat into the domain?
July 1, 2020 at 11:36 am
sunil.voleti
SubscriberHey,
I have glass as substrate and I am moving laser as heatsource. I want to know the melting behaviour of glass due to the effect of laser power.
July 1, 2020 at 2:20 pm
Ansys EmployeeOK, so how does the glass flow and do you need the laser or just a heat source?
July 2, 2020 at 5:50 pm
sunil.voleti
SubscriberIt does not matter laser or heatsource but need to define properties of laser to heatsource in terms of heatflux,etc and also different viscocity for different temperatures, I want to see the melting of glass after reaching melting point during simulation or after the simulation.
for example melting point of glass is 1700 deg.celcius.if my substrate temperature exceeds melting temperature after some time then i have to see melting behaviour of glass
July 3, 2020 at 8:57 am
Ansys EmployeeSo you'll need the melting/solidification model in Fluent. But check with your supervisor what the glass properties are.
July 3, 2020 at 10:00 am
sunil.voleti
Subscriberyes, I need melting and solidification model in fluent for glass material.please help me melting simulation with some glass properties later I will use your model and simulation settings by changing material properties which I need.
July 3, 2020 at 3:48 pm
Ansys EmployeeWe don't supply models, we're here to guide you to solutions. Read up on the melting & solidification model in the manuals (click on Help to access) and also look through the tutorials: the one on solidification should cover most of what you need.
July 3, 2020 at 8:57 pm
sunil.voleti
Subscribercan you help with one simulation example how to simulate melting of glass because I could not find examples related to melting in fluent
July 6, 2020 at 10:52 am
Ansys EmployeeHave you looked at the tutorial I suggested?
July 6, 2020 at 4:41 pm
sunil.voleti
SubscriberI tried different examples with vof and without vof, and with solidification but I cannot see any melting effect and temperature distribution from heatsource to substrate.
July 7, 2020 at 10:35 am
Ansys EmployeeIf there's no heat transfer then there's something else wrong. Are the various volumes connected?
July 8, 2020 at 2:21 pm
July 18, 2020 at 9:01 pm
sunil.voleti
Subscriberhello rwoolhou
could you please help me with melting simulation for this model
July 20, 2020 at 10:55 am
Ansys EmployeeSo, heat is added to the domain, and the glass should get hot. What's happening in your model?
July 20, 2020 at 11:11 am
sunil.voleti
SubscriberI cannot see any melting of glass and I cannot see any temperature transmission from heatsource to glass
July 20, 2020 at 3:49 pm
Ansys EmployeeOK, can you see heat transfer to the domain?
July 20, 2020 at 4:05 pm
sunil.voleti
Subscriberno I cannot see any temperature change
July 21, 2020 at 3:21 pm
Ansys EmployeeSo, even with heat added the domain isn't getting warmer? If that's the case how are you adding heat, and are you adding it in the right place?
July 23, 2020 at 7:33 am
sunil.voleti
Subscriberif possible could you please simulate that model and attachhere I will be most thankful to you
July 23, 2020 at 8:51 am
Ansys EmployeeNo, we can advise but are not permitted to give out models or detailed advice. Start with a model assuming the glass is solid and examine the heat transfer. Once that works, swap the solid for "solid" glass using the VOF model and solidification.
September 23, 2020 at 9:32 am
sunil.voleti
SubscriberHey,ni tried every thing as you said but i cannot see any melting behaviour of my material. I can see only heat transfer between heat source and material. I added link here please see it, I need exactly like that to see how my material melts could you please say how can I achieve -
September 23, 2020 at 2:23 pm
Ansys EmployeeOK, so you modelled the glass as a VOF fluid material, and it's warming up but not melting? n -
September 23, 2020 at 2:43 pm
sunil.voleti
SubscriberI modelled glass and aluminium I tried with solidification and melting also. I tried different models with 3D and 2D geometries.n -
September 23, 2020 at 4:03 pm
Ansys EmployeeAny pictures showing temperature contours through a plane? n -
October 26, 2020 at 11:15 pm
sunil.voleti
SubscriberHai,nplease see the attached video. I simulated with solidification and melting with energy on.I could some temperature change and melting of material inside the block. I would like to see flow of melting liquid to sides of block.n -
October 27, 2020 at 10:27 am
Ansys EmployeeI'm still not allowed to download attachments, please post some images. n -
October 27, 2020 at 11:03 am
October 27, 2020 at 11:45 am
Ansys EmployeeOK, so it's warming up OK. What boundary do you have to cause the red banding on the last image? What is the cell condition for the block?n -
October 27, 2020 at 11:59 am
sunil.voleti
Subscriberi defined as wall and i defined temperature for wallsn -
October 27, 2020 at 12:05 pm
October 27, 2020 at 1:23 pm
DrAmine
Ansys EmployeeDo you see Wall/WallShadow connection on the wall separating the air from glass? Or interfaces in case of non-conformal mesh?n -
October 27, 2020 at 1:33 pm
sunil.voleti
Subscriberyes i can see wall shadowsn -
October 27, 2020 at 1:46 pm
DrAmine
Ansys EmployeeNice!nnAre you now using the melting model? Can you add screenshots showing all relevant aspect of the setup? And the material property for the glass fluid please.n -
October 27, 2020 at 1:53 pm
sunil.voleti
SubscriberI am using solidification and melting with energy on I want to see melting behaviour of glass but my problem is I cannot see any flow of glass after it melted I mean I my model there is Glass surrounded by air. I could see melting inside Glass but I want to see flow of glass fluid to the sides.n -
October 27, 2020 at 1:55 pm
DrAmine
Ansys EmployeeHow the glass melt will flow across the walls?n -
October 27, 2020 at 1:56 pm
October 27, 2020 at 1:57 pm
DrAmine
Ansys EmployeeIt is better to remove the walls, use VOF model with air as primary phase and the glass fluid as secondary phase. For the secondary phase the solidification / melting model will take care about melting. Once the liquidus fraction increases the ability of the glass fluid to flow will increase and flow..n -
sunil.voleti
SubscriberYes I know glass will not flow across walls then what type of boundary I have to define. n -
October 27, 2020 at 1:59 pm
sunil.voleti
Subscriberyou mean VOF with Solidification and melting right?n -
October 27, 2020 at 2:14 pm
sunil.voleti
Subscribercould you please help me what type of boundary conditions i have to define for my model if i use vof and solidification and melting?n -
Ansys EmployeeYes, with an interior surface type. The glass looks to be melting but can't flow because of the wall. n -
October 27, 2020 at 2:20 pm
sunil.voleti
Subscribercould you please help me what type of boundary conditions i have to define for my model if i use vof and solidification and melting?. -
October 27, 2020 at 2:29 pm
sunil.voleti
Subscriberwhat type of boundary conditions i need to define for glass fluid to see flow of materialn -
October 27, 2020 at 3:37 pm
DrAmine
Ansys EmployeeDo not define any wall. Go back to Fluent and just switch wall to interior or in Meshing just call the Wall of the Glass Box interiorn -
October 27, 2020 at 3:47 pm
sunil.voleti
Subscriberwhere i need to define temperature because in fluent if i need to define temperature it should be wall rightn -
October 27, 2020 at 4:00 pm
sunil.voleti
SubscriberI defined interior in meshing and it shows as interior in fluent when the material is solid but if I change if I am changing as fluid in cell zone conditions its showing as walls againn -
October 27, 2020 at 4:29 pm
sunil.voleti
SubscriberI simulated with interior as you said I could not see any melting of glassn -
October 27, 2020 at 7:44 pm
DrAmine
Ansys EmployeeHow did you define the temperature at the beginning? At the walls? What will drive melting: I think the warm air flow.Check the phase glass material properties.n -
October 27, 2020 at 8:01 pm
sunil.voleti
SubscriberI defined temperature in cell zone conditions for Air block with fixed values option n -
October 27, 2020 at 8:05 pm
DrAmine
Ansys EmployeeAre you doing a demo? I would rather patch it as ini value and let it run and adapt itself. For the glass cell zone patch a temperature below solidus.n -
October 27, 2020 at 8:16 pm
sunil.voleti
Subscriberyeah I did patch alson -
October 28, 2020 at 7:54 am
sunil.voleti
SubscriberI need to define gravity or not?n -
October 28, 2020 at 10:11 am
DrAmine
Ansys EmployeeYes.n -
October 28, 2020 at 10:23 am
sunil.voleti
Subscriberok i will try with it.n -
October 28, 2020 at 11:24 am
DrAmine
Ansys Employeeokn -
November 4, 2020 at 8:05 pm
sunil.voleti
Subscriberhai Dr Amine thanks alot for your valuable sugessions. How we can calculate angle of glass before melting and after melting. is it contact angle.if yes how to calculate itn -
November 6, 2020 at 1:42 pm
sunil.voleti
Subscribercould you please help me with defining contact anglen -
November 6, 2020 at 3:40 pm
DrAmine
Ansys EmployeeWhich contact angle?n -
November 26, 2020 at 2:53 pm
sunil.voleti
SubscriberHai DrAmine,nAs you said If I patch temperature for interior is it constant or it changes during the time.n -
November 26, 2020 at 3:00 pm
Ansys EmployeePatch is the initial condition, it will change with time when you run the model assuming the solver is set up correctly. n -
November 26, 2020 at 3:03 pm
sunil.voleti
SubscriberIs there any option to define initial condition in terms of watts or else we can patch only with temp.n -
November 26, 2020 at 3:14 pm
DrAmine
Ansys EmployeeOnly with Temperature as we are solving for Temperature/Enthalpy Equation.n -
November 26, 2020 at 3:22 pm
sunil.voleti
Subscriberhow can i patch different temperatures for interior I mean for different areas of interior different temperatures n -
November 26, 2020 at 3:24 pm
DrAmine
Ansys Employeeif not explicitly already defined as cell zones you will need to create cell registers for the areas.n -
November 26, 2020 at 3:27 pm
sunil.voleti
SubscriberIn my simulation i can see only volume fraction but not liquid fraction what might be the problem.nIf I turn on gravity I am getting error that floating point error.n -
December 10, 2020 at 6:43 pm
sunil.voleti
SubscriberHi DrAmine,ncould you please help me how we can define heatsouce (Laser) instead of temperature.n -
December 12, 2020 at 7:32 am
DrAmine
Ansys EmployeeYou see liquidus fraction and phase volume fraction. n -
DrAmine
Ansys EmployeeHeatsource via a source term applied into energy equation.n -
December 12, 2020 at 3:57 pm
sunil.voleti
SubscriberI did not understand can you please explain little clearn -
December 14, 2020 at 9:58 am
sunil.voleti
Subscriberif i define source term no need to again patch temperature for interior rightn -
December 14, 2020 at 10:29 am
DrAmine
Ansys EmployeeYou can patch if initial condition should be required.n -
January 13, 2021 at 2:15 pm
sunil.voleti
SubscriberIn source term to define energy source for 2D model its showing w/m3 units but we use that unit for 3D model because it is volume. how can I change units as w/m2 for 2D model.n -
January 13, 2021 at 4:45 pm
Ansys EmployeeIt's still W/m3 in 2d. If you've not touched the reference values the domain is 1m deep: axi symmetric is Pi radians (check that) sector. If you have changed the reference values, change it back to 1m depth. n -
January 13, 2021 at 8:07 pm
sunil.voleti
Subscriberyou mean if I use axisymmrtric no depth in reference values then it will be correct for 2d model right n -
January 14, 2021 at 11:12 am
Ansys EmployeeIf it's axi-symmetric the domain is assumed to be a sector, of Pi or 2Pi radians (I can never remember which so tend to use an area calc to check). If you change the depth value in the reference values you risk the boundary retaining a hard coded depth but you reporting based on the reference. n -
January 29, 2021 at 9:51 am
sunil.voleti
Subscriberif i change depth as zero what it represents? Is it 2D or 3Dn -
January 29, 2021 at 9:53 am
sunil.voleti
SubscriberAs I am using asisymmetric all the interior walls are becoming axis automatically in fluentn -
January 29, 2021 at 10:05 am
DrAmine
Ansys EmployeeYou are using axiss-ymmetric with the x-axis being the axis of rotation: you cannot modify the way Fluent is storing the volume here.n -
January 29, 2021 at 10:08 am
sunil.voleti
SubscriberDo i need to define any axis or just I have to choose axi symmetric instead of planarn -
January 29, 2021 at 10:38 am
DrAmine
Ansys EmployeeFluent expects that the x-direction is your axis of rotation. You need to make that happen. (Gravity if enabled should be in parallel to that direction too)n -
Ansys EmployeeIf you change the reference depth to zero (in 2d) it's still 2d but all the calculations that require an area (or volume) could return interesting results. How about leaving the reference depth alone and instead use the results to see what's going on in your model? nIf you set the domain to be zero thickness in 3d (no idea how as you'll no longer have a volume) the cells will either have an aspect ratio of infinity and/or the mesh will fail to read into Fluent. n -
January 29, 2021 at 10:50 am
sunil.voleti
Subscribermy problem is I want to simulate 2D model with planar. I need to define energysource with source term options but the units are in W/m3. how i can define w/m2 insted of W/m3. n -
January 29, 2021 at 10:56 am
sunil.voleti
SubscriberAs ROB said me before its still W/m3 in 2D. if i define 2D energy value in energy source does fluent calculates solution correctly?n -
January 29, 2021 at 11:42 am
Ansys EmployeeIt does, because you assume the 2d domain is 1m thick (if you've not been messing with the reference) when working out the source volume. If you initialise the model & do a volume check on the fluid it'll give a volume in m3. n -
January 29, 2021 at 12:38 pm
DrAmine
Ansys EmployeeYou need to provide the sources in terms of W/m?. The depth is under reference values. Default is one meter.n -
February 24, 2021 at 2:30 pm
sunil.voleti
Subscriberwhat type of viscosity I need to define in ansys fluent I mean LOG viscosity or dynamic viscosity?n -
February 25, 2021 at 12:09 pm
Ansys EmployeeHave a look at the units, that'll give you a good idea. n -
March 1, 2021 at 9:24 pm
sunil.voleti
Subscriberif I define energy with source terms in ansys I cannot see any contour change in terms of temperature. Is it possible to get temperature or its not possible. n -
March 2, 2021 at 4:50 pm
Ansys EmployeeYou should, how much energy are you adding when compared to how much mass? n -
March 3, 2021 at 12:38 pm
sunil.voleti
SubscriberI did not understand what you mean exactly could you please expain in detail ?n -
March 3, 2021 at 12:58 pm
Karthik R
AdministratorWhat means is - how does your total input energy (in J) compare to the sensible and latent heat added to your fluid. This is a simple hypothetical energy balance.nm x Cp x del_T vs. Total input energynCompare these two quantities and see how much del_T you should expect if all the heat were added to increase the temperature. If this is small, then if you have phase change in your simulation, this temperature change would be further reduced.nKarthikn -
March 10, 2021 at 10:36 am
sunil.voleti
SubscriberHello,nHow we can define radiation (Emmisivity coefficient) in fluent to our model?n -
March 10, 2021 at 12:03 pm
Ansys EmployeeAbsorption is is a material property, emissivity is a surface value and is set in the boundary conditions. n -
March 31, 2021 at 3:50 pm
sunil.voleti
Subscriberhello Karthik nI could see temperature in simulation but I cannnot see temperature where I have defined my energy I could see some where in my model could you please help me with this. n -
April 1, 2021 at 10:40 am
Ansys EmployeeWhat can and can't you see? n -
April 1, 2021 at 4:02 pm
sunil.voleti
SubscriberI mean its showing temperature but as not expected its showing very less temperature could you help me what might the problem. I defined energy in source terms.n -
April 2, 2021 at 3:08 pm
Karthik R
AdministratorWhat is your input energy? What does your flow look like and what temperatures are you seeing? You need to give us this data so we can help. nPlease check the overall energy balance in your simulation and make sure that you are conserving energy.nKarthikn -
April 20, 2021 at 7:05 am
sunil.voleti
Subscriber -
April 20, 2021 at 10:54 am
Ansys EmployeeDo a hand calculation of the source and plot that in Excel.n -
April 20, 2021 at 11:24 am
sunil.voleti
SubscriberI have calculated with same equation in excel it shows correct results with decreasing temperature but in simulation temperature was increasing n -
April 20, 2021 at 12:36 pm
Ansys EmployeeIf you're adding more energy than is leaving it'll heat up. Where is the heat going, and does it balance? n -
April 20, 2021 at 1:18 pm
sunil.voleti
SubscriberI am patching for example 2400?c at the start of simulation and I have set in properties as 1500?c is solidus temperature and 1700?c as liqudious temperature. Is it true what I am defining?n -
sunil.voleti
SubscriberI want to see melting of material during the timen -
April 20, 2021 at 2:37 pm
Ansys EmployeeOK, and you're also adding heat into the domain. How does that heat leave the domain? n -
April 20, 2021 at 2:41 pm
sunil.voleti
SubscriberI have outletn -
April 20, 2021 at 3:02 pm
Ansys EmployeeOK, and does heat leave through the outlet faster or slower than you're adding it through the source? What about any walls in the domain? n
3744
2573
1803
1236
594
