“Memory allocation error ” in Maxwell 3D design
    • Sivagami
      I have simulated pairs of coils for wireless power transfer, aiming to find coupling co-efficient. But this error is new to me. Memory allocation error followed by Failed to evaluate calculatio.nWhat could be the probable reasons?nThank you,nSivagami K
    • icellb1
      Hi, @Sivagami,nCould you describe more details of your setup, we'll try to find someone to answer your question. For now, you can try reducing the complexity of your setup (create simpler geometry, reduce the ratio of biggest dimension to smallest dimension, make mesh coarser, etc). Also check you computer memory, usually at least 16 GB memory is need for many simulations.n
