Memory Error for Loop
    • lancelim
      Hi:
      I am running ANSYS via batch mode with a do loop.
      After every loop I have to clear the geometry and recreate everything.
      When the loops get too large I get the following error:
      "*** MEMORY ERROR ***
      The low level memory manager failed to return a valid memory handle for a free operation.
      Pointer value: 984866781, Filename: ..srcCINT_Crack.cpp, Line: 167.
      It is likely that the code is calling for a free with a pointer that was not allocated via the memory manager."
      Is there a way I can free up the memory halfway through the loop?
    • Chandra Sekaran
      Looks like there is a memory leak. Are you doing a "finish" and "/clear" at the beginning of each loop? Also may be you can create a dummy 'empty.db' with nothing in it and then resume it at the beginning of each loop?
