Memory Size requested not Available
    • ILEFde22
      *** FATAL *** CP = 0.718 TIME= 21:23:12
      The memory (-m) size requested [1024 mb] is not currently available on
      one of the other Distributed ANSYS processes. Reenter ANSYS command
      line with less memory requested.
      when I tried to solve for the directional heat flux, I encountered this problem several times. I am not sure what should I change to make it work.
      I have solved for other thermals with no problem and I am working on a 2 D convection problem.
    • peteroznewman
      Does your computer have < 4 GB of RAM installed?
