MEMs micro-mirror simulation
    • Abhijit abhattacharya
      What will be the best Ansys solver or method to simulate & extract "Quality-Factor" of a MEMS micromirror structure (clamped double-sided at its shorter sides and the actuation mechanism is electrostatic).
      Kindly share your comments/suggestions and if some documentation or tutorial-examples available.
      Regards
    • Erik Kostson
      Hi
      The only thing that is perhaps a bit similar and that might be of some help, is an example in our help manual (Coupled field analysis – electrostatic-structural section) .
      It is called:
      2.4.8. Example: Electrostatic-Structural Analysis of a Micromirror
      2.4. Electrostatic-Structural Analysis (ansys.com)
      Thanks, that helps.
