Preprocessing
Preprocessing
    • MKSummers
      Hi guys, does anyone here know how to fix this mesh?
      The gap or the abysmal quality? For the former check the geometry, for the latter read up on global mesh settings, size functions and unstructured meshes.
    • Keyur Kanade
      please check no. of edges for that particular highlighted face. for getting map mesh, it should have only four edges.
      if it is more than 4 edges, please use virtual topology. you can search about VT on community and help.
      Keyur
