Preprocessing
Preprocessing
    • Prathmeshsanas2
      hello,
      can anyone solve the meshing of following object(car door)??
      Type of meshing to be used: 2D Quad Meshing (up to 10% tria elements allowed)
      (NOTE: The mesh size should be such that the variation in output between the two consecutive mesh sizes should be zero or minimal)
       limit- Nodes -32000
               Elements- 32000
    • Karthik R
      Administrator
      I don't quite understand the issue. Could you please share some screenshots and help me understand the issue better?
      Also, please note that Ansys employees are not able to download the files from the community. Please use the "insert image" option to add the screenshots.
      Thank you.
      Karthik
    • Keyur Kanade
      As ANSYS Staff, we can not download attachments. Please insert images using insert image functionality.
      From your description, you will need constant size quad 2D mesh.
      This can be done in Workbench Meshing.
      Please see meshing methods and sizing functions in help manual.
      Keyur
