November 10, 2020 at 2:33 pm
Lugia_06
SubscriberHi everyone,
In another post previously(https://forum.ansys.com/discussion/21666/mesh-adaption-by-aspect-ratio-field-variable#latest), I was asking if there is any way for mesh adaption to only reduce the aspect ratio in some area and the answer was anisotropic adaption, however, the ansys anisotropic adaption only limited to 3D tetra mesh.
Is there any alternatives for 2D anisotropic adaption in Fluent? All I need to do is just changing the aspect ratio in the outlet cell zone, but the mesh module always gives unstructural mesh either around the corner of the outlet orifice or far back at the inlet zone. I used face meshing for the whole geometry and edge sized the outlet bit, could anyone explain why the quad mesh disabled at the orifice fillet and how I should fix this issue? From the look of it the edge sizing at the outlet should not be related to the orifice right?
Outlet element size 9e-6 m in x direction
November 12, 2020 at 4:26 pmRK
Ansys EmployeeHello, nAt the moment, there is no alternative for a 2D anisotropic adaptation. nCan you please insert an image of the model with labels to better understand the last part of your question? Thanks. nViewing 1 reply thread- The topic ‘Mesh adaption aspect ratio’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3151
1680
1470
