March 21, 2021 at 4:37 pm
Mohamed_Wael_Badawy
SubscriberDear sir,
I am simulating the motion of a droplet in a micro-channel where the droplet dynamics is highly dependent on the thin layer of fluid between the interface and the wall boundaries.
I am trying to use VOF mesh adaption while i am using inflated mesh near the boundaries. However, I am always facing the problem of having a layer of non-adapted mesh between the inflated layers and the adapted zone. I have tried to separate the inflated mesh zone and retry the mesh adaption but i got the same results. I would like to know if there is a method that can successfully adapt the mesh according to the VOF in the vicinity of the inflated mesh zone.
March 22, 2021 at 3:48 amKeyur Kanade
Ansys EmployeeWhat is cell count? nStudent version has limit of 512K cells. nIs this full hex mesh? Do you see similar behavior with tet mesh? nWhat is criteria used for adaption? nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynnMarch 22, 2021 at 8:41 amMohamed_Wael_Badawy
SubscriberThanks for your reply. I am using VOF gradient adaptionn I FINALLY managed to overcome this issue, I changed the minimum orthogonality ratio in the advanced mesh adaption to zero and it worked!nnMarch 22, 2021 at 3:10 pmYasserSelima
SubscribernGood .. you have been in this issue for a while!nMarch 24, 2021 at 6:47 pmMohamed_Wael_Badawy
SubscriberArray Yes Finallyn
Viewing 4 reply threads- You must be logged in to reply to this topic.
2688
2138
1355
1140
462
