March 6, 2021 at 6:54 am
Mohamed_Wael_Badawy
SubscriberDear sir,
I am simulating the motion of a droplet in a micro-channel where the droplet dynamics is highly dependent on the thin layer of fluid between the interface and the wall boundaries.
I am trying to use VOF mesh adaption while i am using inflated mesh near the boundaries. However, I am always facing the problem of having a layer of non-adapted mesh between the inflated layers and the adapted zone. I have tried to separate the inflated mesh zone and retry the mesh adaption but i got the same results. I would like to know if there is a method that can successfully adapt the mesh according to the VOF in the vicinity of the inflated mesh zone.
March 6, 2021 at 1:17 pmYasserSelima
SubscriberDo the adoption by coordinates using expression. Let's say you want to adopt the cells between x=0.05 m to x=0.1m ... use this expressionnIF(AND(Position.x < 0.1[m],Position.x>0.05[m]) , 1,0)nMarch 6, 2021 at 1:29 pmMarch 6, 2021 at 1:39 pmYasserSelima
SubscriberTry it without < .. like thisnIF(Position.y >0.05[m] , 1,0)nnMarch 6, 2021 at 1:54 pmMohamed_Wael_Badawy
SubscriberSame result. Fluent intentionally leaves a layer of 1 element thick unadapted next to the inflated layers.nMarch 6, 2021 at 1:58 pmYasserSelima
SubscriberNot sure how to solve this. nYou have no option but going back to meshing if you want to solve this soon. The Ansys experts are off in the weekendsnMarch 6, 2021 at 2:04 pmMohamed_Wael_Badawy
SubscriberThanks for your help. What do you mean by going back to meshing?nMarch 6, 2021 at 2:06 pmYasserSelima
SubscriberHow did you create your mesh in the first place. Go there and select smaller element size for this wall. And re-meshnMarch 24, 2021 at 6:48 pmMohamed_Wael_Badawy
SubscriberI FINALLY managed to overcome this issue, I changed the minimum orthogonality ratio in the advanced mesh adaption to zero and it worked!nMarch 24, 2021 at 8:08 pmYasserSelima
SubscriberThanks for sharing the solution!nViewing 9 reply threads- You must be logged in to reply to this topic.
2706
2146
1357
1144
462
