mesh adaption
    • A1234
      Hello
      for mesh adaption in fluent.in default it divide each mesh to 4 then 8 sub mesh.
      how can i divide each mesh to just 4 sub mesh?
    • Karthik R
      Administrator
      Hi,nYou adaption is dependent on the criteria you have set. If you use the default settings with 2 levels of refinement, whenever your criterion is met, Fluent will use this number to split your cells. So, what is your criterion for adaption? nCan you change the levels on your contour from 20 (default) to 2. In this case, you will have just 2 colors - red and blue. Another way would be to create an iso-surface of VoF = 0.5. For a surface, this will be a line and you should be able to display this line on your contour plot.nI hope this helps.nThanks.nKarthikn
    • A1234
      thanks nbest regardsn
