November 12, 2018 at 7:53 pm
alan17
SubscriberI have used the Mesh connection tool in Workbench for creating the attached central crack plate model. Is there a similar mesh connection tool/code in APDL?
November 12, 2018 at 11:57 pm
Sandeep Medikonda
Ansys EmployeeHi alan,
I am assuming you are referring to this tool. If so, there isn't anything equivalent and you would have to do the necessary operations using commands. I would suggest you to write out an Input file from Tools>Write Input File in mechanical, look out for the commands that are being written out and go from there.
Sandeep
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2706
2142
1355
1144
462
