January 12, 2023 at 3:53 pm
Anders Kjaer
SubscriberIs there anyway to decide the element type in AEDT, particularly maxwell?
No matter what I do, I can only mesh with triagonal elements in 2D or tetrahedral elements in 3D. I tried creating a mesh file using hypermesh 2021, but i can't even figure out how to import the mesh.
I've read somewhere that you can use Ansys workbench, but as I don't have a license for that, that is not an option. -
January 17, 2023 at 1:18 pm
Navya C
Ansys EmployeeHi Anders,
You can not change the type of mesh elements. But you can always refine the mesh using the initial mesh settings and other mesh settings available.
You can import the mesh from one Maxwell to another Maxwell model provided the geometries are the same.
Navya
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1283
1096
459
