September 12, 2019 at 4:32 pm
kishenharidas
SubscriberHello all,
i'm curently working on an APDL coupled field analysis project and I'm fairly new to Ansys. I would like to know how to display the mesh in APDL instead of node points. I created the geometry and initial boundary conditions and wrote a script file that i read using APDL. I have attached an example image where the meshes are clearly defined and also color coded(IMG1), whereas in the file that i generated(IMG2), only node points are visible and not the mesh. Could someone please guide me here. Also, how is color coding of mesh done in APDL? I've attached the 2 images [IMG1 and IMG2]
Thank you.
October 28, 2019 at 5:33 pm
sathya
SubscriberHi,
the command you can use is
ALLSEL,ALL
EPLOT
2098
1323
1110
461
