August 7, 2019 at 1:40 am
nevertrust
SubscriberI have a problem to understand how ansys workbench generate number of element after providing mesh size element?
If i have a model of 1m X 1m X 1m (length X breathX height) and i provide element size as 0.5m then my total number of element for model is 8. may be i am wrong.
I have a model of 3mX2mX0.3m ( length X height X width) if i provide 0.3m element size on that model (explict Dynamic). My problem is how it will divide my model to provide number of element? specially from height part
if we have a calculation
2/0.3 we get 6.66.
Do we have other method to apply mesh size to remove error?
Waiting for your response.
Thank you
August 7, 2019 at 2:27 pm
Ansys EmployeeYou'll not get part elements, the meshing tool will adjust the cell size to fit into the domain with full cells. What error are you seeing/worried about?
August 8, 2019 at 2:04 am
nevertrust
SubscriberThank you for your help.
I was worry about part elements and now i understand I got error because of large element size. in above case can we consider our element size is 0.3m for all elements?
Thank you.
August 8, 2019 at 9:39 am
Ansys EmployeeHave a look at the hard and soft size settings. In terms of cell size, we also look at mesh resolution: do you have enough cells to calculate the stress/strain/bendiness etc you're going to observe? You could use 0.3m sizing giving 10 x 7 x 1 cells but it may not be sufficiently resolved.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1279
1096
459
