Mesh error after setting up composite in ACP pre
    • Dioser
      Hey everyone,
      I am using Workbench with ACP pre to set up composite material, stackups and directions for an aircraft structure, as shown in the pictures below. For reference, I used this great tutorial from YT, just adapting the methods to my problem:
      ","embedType":"youtube","name":"Composite Wing Analysis - Ansys ACP and Mechanical 2020R2","frameSrc":"https://www.youtube.com/embed/7q6ZED14Cas?feature=oembed&autoplay=1"}">
    • Govindan Nagappan
      Check the units in ACP and also Mechanical
      Also check the units in the project schematic:
      Did you assemble meshes in Static structural system? Try using a new static structural system and send the mesh from ACP. See if it fixes the issue
      If not, your project may have corrupt data that could be causing this issue
