Mesh error in Ansys Sherlock
    • Sidrah
      I am using Ansys Sherlcok for petrformance prediction of my PCB. I ran all the analyses they were doing fine unless today I chnaged the package of DB9 cinnector.
      Now I am getting error saying "Mesh edge from (x1, y1) to (x2,y2) is not associated with any faces".
      I am getting tghis eeor in several analyses (Thermal Mech, Rando Vbe, Natural Freq....).
      Please tell me what does this error mean? Is this error associated with packagae type? And what is the way out from this error?
      Thanks in advance.
      Note: The error is showing multiple coordinates I just used dummy values in terms of x &y.
    • Sean Harvey
      Hello Sidrah,
      There are 2 possibilities, maybe you are using an older version of Sherlock such as  2020 R1 or earlier which it uses Sherlock’s legacy mesh. If not can you change the mesh size slightly and that can help fix the issue.
      Thank you!
      Sean
