May 15, 2022 at 9:02 am
Qbicc
SubscriberHello,
I am trying to create a model depening on several parameters.
Currently I am try to check the convergence of the results by changing the element size of the important region and comparing the results.
I get a lot of meshing errors when doing so over the parameter interface and after checking what is going wrong in mechanical directly, I found the problem:
When I change the element size of the important region and clear generated data everything is fine. However when I change the element size and do not clear generated data, Ansys views only that part of the mesh as obsolete and recreates it. This unfortunately leads to a really bad mesh, because the important part of the mesh must be created first to reach a good mesh quality.
I made a video of the problem and uploaded it into google drive (less than 45mb):
May 17, 2022 at 6:01 amKeyur Kanade
Ansys EmployeeAs Ansys Staff, we can not download attachments. Please upload images using upload image functionality.
If you want to generate mesh with specific sequence, you can use worksheet.
Please go through help manual for more details
For geometry cell please use compare parts on update as No as shown below.
Regards Keyur
May 17, 2022 at 4:19 pmQbicc
SubscriberThank you very much "Compare Parts On Update" was exactly what I was looking for.
Kind Regards
Qbicc
Viewing 2 reply threads- The topic ‘Mesh errors when changing mesh parameters only partially’ is closed to new replies.
Trending discussions- Floating point exception
- How to indetify baffles in Fluent meshing
- How to delete elements on Ansys Workbench
- Meshing cylindrical bodies with holes
- Quality failure limits are exceeded on some solid bodies… in ansys meshing
- Problems in the meshing of my geometry
- Ansys Mechanical – Python Scripting – Access and input parameter
- Mesh Element Quality Display Style Not Showing
- Fluent Meshing Batch Mode – Problems workflow commands
- Local mesh refinement with targeted edge lengths at specified areas
8808
4658
3153
1688
1478
