Preprocessing
Preprocessing
Mesh fails at corner
    • moustafa
      I am trying to mesh a geometry which is, at some points, poorly designed. There is this overhang of 0.17 mm where the mesh fails. What can I do to mesh this geometry?
      Thanks in advance :)
    • Ashish Khemka
      Can you share the geometry images without mesh? Also, can you share zoomed-in image for the region which looks problematic?
      Ashish Khemka
    • peteroznewman
      Try using a larger value for the Mesh-based Defeature Tolerance.
      ANSYS meshing problem, I've tried a lot of ways to fix the error but  nothing works, any suggestion to fix it?
